> Людт помогите плз с игрой, ошибка
KillerSnoop
сообщение 20.6.2008, 9:40
Пользователь №: 41984
Скачал себе проект 51, попробовал зайти, меня выбивает и пишет вот такую фишку -
Wolf 1.32 win-x86 May 1 2002
----- FS_Startup -----
Current search path:
C:\Program Files\Project 51\main\sp_pak5.pk3 (1261 files)
C:\Program Files\Project 51\main\sp_pak4.pk3 (21 files)
C:\Program Files\Project 51\main\sp_pak3.pk3 (274 files)
C:\Program Files\Project 51\main\sp_pak2.pk3 (232 files)
C:\Program Files\Project 51\main\sp_pak1.pk3 (1319 files)
C:\Program Files\Project 51\main\pak0.pk3 (5050 files)
C:\Program Files\Project 51/main
8157 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 6: 1024 768 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (6)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD( 16, 24, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Помогите плз, очень хочется поиграть, пробовал устанавливать все вульфы, все не пашут, говорят одно и тоже
Spies
сообщение 20.6.2008, 14:39
Из: Соколиная гора
Пользователь №: 40823
Драйвера для видео необходимо поставить, ну соотвественно лучше последние.Стандартные виндовые дрова неподходят
Сообщение отредактировал Spies - 20.6.2008, 14:40
KillerSnoop
сообщение 20.6.2008, 14:42
Оо! Заработало =) Спасибо
KillerSnoop
сообщение 21.6.2008, 19:08
Люди дайте ссылку плиз на оригинал игру, а тоесть return to castle wolfenstein, ато везде то чужая территория и тд sad.gif
Spies
сообщение 23.6.2008, 15:57
Из: Соколиная гора
У меня в DC лежит 5 частей RTCW, вот тока когда там буду непонятно, траблы с сетевой (усё проблему устранил)
Сообщение отредактировал Spies - 24.6.2008, 0:18
KillerSnoop
сообщение 24.6.2008, 7:11
Тогда я сегодня вечерком зайду в ДЦ, если будет свободное время
